Glass & lights
I got this problem while using some kind of glass material. Glass completely disappear when is in front of Corona Lights as well Rectangle as Sphere. The problem is still with frozen lights.
Greetings!
Isn’t this a hardware error? This doesn’t happen when you use standard materials? I usually disable transparency in viewport, this fixes everything. :tongue:
maybe it’s just in the viewport and a graphic card problem
did you try a render?
I’m using Nitrous as viewport driver (GF GTX 250 with last driver). And this issue is only connected with Corona when I enable transparency in it . It is rendering properly, but the other issue is even when You check off “directly visible” in light, it is still visible in render.
Unable to reproduce, maybe send a scene if it still happens in alpha 4
