glossiness adjustment
Have a problem with the glossiness adjustment spinner - It does not allow me to input values beyond .1 increments. I.e a value between .8 and .9 is not possible. This is probably an issue with MAX, but may be Vray as Ive installed the latest version. Can someone help…?
Am trying to finish a project for close today.
Thanks..
In 3dsmax, check
customize - preferences - general
There, in SPINNERS section You’ll find ‘precision’ spinner.
set it to the number of decimals You wish to have available in the spinners.
If that’s not it - then AFAIK it’s not a 3dsmax issue.
cheers!
ta!
…didnt think it was vray - thanks. When so close to a deadline I cant see the wood for the trees.!
