GPU as IPR: Fit resolution to VFB
Is there a way to disable this? I would like to use GPU as IPR, but with a fixed resolution.
When you start “IPR” with the GPU engine, it simply runs the Active Shade. There is an option if you want the render resolution to fit the VFB there.
Best,
Blago.
Where do I find that?
EDIT: Found it. Wow, that is one inconvenient way to do it! Literally the last place where I would have looked.
