Hi @npg
Thank you for your answers. Yes, I understand, that NVlink doesn’t double GPU RAM in Chaos Vantage, but this will be awesome if you will add this in the future. =)
The low framerate is likely worsened by the OS swapping memory back and forth between the GPU and main RAM. That happens when you allow overallocations by disabling the “safe” option.
So, as I understand, this is like turning on the “Out of Core” in V-ray. Right? =) And this is slow down the FPS =) Because scene eats more free GPU RAM than I have on 1x2080Ti, right? =)
Hi @vladimir.nedev
So, I increase FPS to 20-30 with “use localhost”. Thank you =) In the previous test, it was disabled…
are you simultaneously running V-Ray GPU inside 3ds Max ?
Like as in the tutorial. Selected “distribution render” - on and started IPR.
Other GPU heavy applications running in the background, like 3dsMax, games or other renderers can also eat up the memory available to Vantage.
I just started 3ds max + Vantage. There is no game and etc =)
You might have to run Vantage on a GPU that’s not simultaneously used by 3ds Max in order to have more memory available.
So, your advice is to disable one GPU in V-ray 3ds max? Or how to do that? =) But why, when I don’t use “Safe GPU” option - everything is ok? =)
Can you upload the full scene (.max file and textures) and send me a link on my e-mail.
Yes, no problem. Done =)
We need all of it to try to reproduce the issue and improve the code that checks for an “out of memory” condition, we might be able to avoid the crash.
Ok. I already sent the scene to your email. Please check =)
Thank you and have a great day
Andrew.
