GPU Distributed rendering - OSL maps log errors
When using GPU distributed rendering and material with Bitmap + OSL map, V-Ray log is showing some errors. The final image is not affected form these errors.
Same scene on local GPU (distribute render turned off) will render without any errors in the log.
I can see the errors in 3ds Max 2021 + V-Ray 5.1 and 3ds Max 2022 + V-Ray 5.2.
This is a test scene: https://www.dropbox.com/s/88bvoqxdch…_Dist.zip?dl=1
Thanks for the report.
We have reported the issue in our bug-tracker (VMAX-2249) for further investigation and resolution. The OSL maps render fine here. The error is related to the transfer missing assets option.
When we have any news from our developers, we will post an update.
