We’ve recently released a hotfix addressing some GPU issues. Can you confirm that you’re receiving those errors after updating to our latest hotfix for V-Ray for Rhino 5, update 2.1? You can get it directly from here: Download | My Chaos
If the issue persists, please send us a packed version with your project files via our contact form. Make sure to mention this thread in the form subject. Much appreciated!
Hi Nikoleta! Yes, it is happening after the update for me too. Regarding the bug where I am not able to work after the error pops up, is it possible to change it in the new update?
About the file, is it possible to send you the file in private? Please let me know how
As soon as we resolve the issue, the resolution will come up in a following hotfix. Best would be to use our contact form, just make sure to mention this thread in the subject.
Seems like this problem is related to having RTX graphic card, I tried with just the CPU rendered and, while it took longer, it was perfect the result. Perhaps it has something to do with both recent updates from NVidia and Vray not being compatible at all? 5.1 was way better for this
Hi! This is still happening and quite a lot. Is there an update coming closer so this won’t happen again? My solution was to do CUDA with both RTX and processor, however, this makes the rendering time slower. I want to use just the RTX option and seems like this error happens when the RTX option is activated and I have a plant. This is so uncomfortable.
I would like to come back to the subject of the 7050 error code because I still have this problem with Vray for Sketchup
Have you found a solution to work around this problem or is an update of Vray planned soon ?
Thanks a lot.
Config; Windows 10 Professionnel 64 bit (build 10.0.19044), Intel Core i7-10700 2,90 GHz, Ram: 32 Go, Nvidia GeForce RTX 3060 Ti
Programs: Sketchup Proc 22.0.316 / Vray for Skecthup 5.20.04
Muhhamed told me in vray gpu forums that they are working hard on this subject vray gpu light cache, i believe we are going to enjoy 5.2 soon with out issues.
I trust in vray gpu developers since they resolved so many issues before this one.
They need time since bringing light cache from cpu to gpu was a Big task.
Muhammed told me that they are working too on the speed of light cache with gpu, is going to be faster than the last time.
You can see the treat if You want. We are all waiting 5.2 since they brought a Lot of things with the new update.
There has been another update published recently - V-Ray 5 for Rhino, update 2.4
Just keep in mind that if the error was popping up because of insufficient memory, chances are the new update will not fix it.
The thing is, with the introduction of the GPU light cache (in the initial 5.2) the memory requirements of V-Ray GPU have increased a bit.
This means that if you were rendering a scene at the limit before (using something like 7.6 GB with a 8GB GPU), it is possible that after the 5.2 release you are no longer able to render.
