Afternoon!
Is there a chance of having the GPU preview window active at all times when not having Phoenix selected. Would be a lot easier for lighting setup
I know we got viewport preview but I still havenât switched to 2016 properly. If it isnât do-able because of max then nevermind.
should be not a problem, perhaps the best solution is to obey the preview option âonly if selectedâ
Yea that would be good, as it currently works fine for the voxel preview, just extend it to work with the GPU :). Will save a lot of going back and forth between lights and grid etc.
Yup, totally doable, but we were hoping youâd use the viewport one
Will check it in a couple of days after we clear some of the more scarier issues.
