Grain Grain Grain
For example, you can set the the Fine subdivs to a high value - like 100
vlado what do you mean with “fine” max. or min. subdivs?
best regrads
themaxxer
I for one would also love to see simple two-level antialiaing put back in the current vray - as a fourth AA ooption, not as a replacement to QMC. I too have never been able to get QMC antialiasing to match the same level speed-for-quality that two level in 1.09 gives me. Which probably explains why I still use ‘old reliable’ 1.09 rather than 1.47 for most work.
Sure, simple two-level can take longer to render if you get the settings wrong, as Vlado once said, but if you do it right, in my experience, it can produce more optimised results than QMC. I for one miss its flexibility.
Vlado, what are the chances of it making a ‘comeback special’?
