We are attempting to switch to 1.47 from 1.09 however a few problems still trouble me. I have read as many posts as I can and still see no clear answer. The speed is the first hurdle…as I have come close to the same speed, the images are not of the same quality.
What happened to Simple two-level? Adaptive QMC isnt even close. The following test images are setup in both versions with comparative settings.
1.09 with Simple two-level and a vraylight, subdivs=10
1.47 with Adaptive QMC and vraylight subdivs=10
Notice how bad the line details from QMC noise are in 1.47…
1.09 with Simple two-level and vraylight subdivs=10
Now, the grain on the walls can be solved by raising the light subdivs to about 30. Thus doubling the render time. The grain noise on the line details can be solved by raising the QMC min and max as well as lowering the noise thrhd, pushing the rendering time another 2x.
None of which really works for animation where time is everything. Can anyone give me some suggestions based on these simple settings. The object here is to keep rendertimes within the same zone as 1.09.
One thing i notice in the first renders, is around the light recesses on the 1.47.02 render there is some noticeable black squares, as if its not being smoothed. Looks like it could be co-planar faces? Do you know if this could be the case?
Also try turning off the IR map blur in 1.47 might help, or try turning it up.
Here, we are still running the 1.09.03r because we have a render farm of over 100 computers. We did not upgrade to 1.47 because this take a lot of time and we cannot afford a last minute problem with a beta release. So, can someone (Vlado… ) tell me when we will have a final version that we can use normally.
I’ve tried the 1.47.02 version and I really love the Light cache method.
When using adaptive QMC AA, you should use other values for the QMC sampler, but leave the min max at default values.
I usually use adaptive QMC 1/4 and the noise th in QMC sampler=0.001 (or 0.002). (don’t use 2/4 and 0.001 because that will only render longer without much visible result)
Note that when you lower the noise th, your IR map calculation will also take longer. The new builds take more samples by default than the old one, so you can get away with coarser values for it to compensate. For example hsph can be lowered, and Clr & Nrm can be higher (altough they are not too low in your settings).
I would definatly try Lightcache to speed things up.
No, sorry, I was trying to use real details without getting too detailed for a more accurate result in time and quaility.
However, that being said, I am now experimenting with Vlados file…
I’ve been playing a bit with your scene; as much as I hate to say it, there is no way to get the same noise level for the same speed. The same quality result took about 4 mins (where the 1.09.03 version took 2m 40s). The main cause for the difference is because of the way the image sampler interacts with the area light samples.
However, when the scene starts to get more complicated (higher irradiance map settings, some texture maps, correct 1.0 secondary GI multiplier, better AA), the new version gets faster than the old one. Using the light cache also gives the new version an advantage.
Have you tried the good old Adaptive subdivision AA? I’ve found that QMC is just noisy by nature. It is Quasi Monti Carlo after all. It’s supposed to simulate random jittered samples. Noise is the out come in a lot of cases. Adaptive Subdivision is just super sampling. Vlado, wouldn’t setting the Subdiv’s to 1 and 1 be the equivalent of the two level sampler? Or am I misunderstanding something?
Well, Adaptive subdivision with Min/Max rate 0/2 is the closest to the old Two-level sampler; in images with large smooth areas without detail, it will be faster than the Adaptive QMC sampler.
Well, the two-level method had its issues too… it could get very slow when you have lots of details that need supersampling - sometimes even slower than the fixed sampler. The adaptive qmc method is somewhat more reliable in that regard, with less variation of render times.
The great advantage of the adaptive qmc sampler is that it is highly adaptive - i.e. takes a different amount of samples based on the desired noise level. Basically, it does something very similar to the path tracing mode of the Light cache, but on a bucket level, with varying amount of samples. This can be very useful for high quality images. For example, you can set the the Fine subdivs to a high value - like 100, and forget entirely about Subdivs in lights, materials, direct GI, moblur, DOF etc. You just use the Noise threshold to set the desired image quality - something that you couldn’t do with the two-level sampler.
Vlado, does that mean that when you set min samples in qmc roullout to for example 40, and you have all materials and lights with for example 8 samples, that all these will be given 40 samples instead of the 8?
No; the Min samples parameter in the QMC sampler rollout will not increase samples beyond the value specified by the user (which is 8 x 8 = 64 for 8 subdivs).
However, if you have, for example, fixed AA with 40 subdivs, that will cause all materials and lights to use at least 40 sudivs too. Adaptive QMC aa however may take less than those 40 subdivs, depending on the noise you get.
