Grass Carpet
I need to make a Grass Carpet for an interior rendering…would this be a job for VrayFur? I have never used it.
Could anyone point me in the right direction, I would really appreciate it.
Eric
if you’re close up like this I don’t think vray fur would hold up. But what you could do is model a few grass blades yourself and scatter them on an object with this free script for example: http://www.scriptspot.com/3ds-max/scripts/ultimate-painter or even use pflow for scattering.
Forestpack, multiscatter, vraypattern, can scatter vrayproxies. For instance Bertrand Benoit uses Forest Pack here to create a carpet: http://bertrand-benoit.com/blog/2011/02/20/shag-carpet-using-forest-pack/
As there is not really much detail you could use vrayfur ofcourse, there are a lot of tutorials tackling this on youtube
Eric, I had this file hanging around from a test I did years ago using Vray Fur. I’ll UL it if you like…
-Alan
Hi Alan,
Yes please send it to me, that should work fine. :slight_smile:
Thanks!
Here you go…
-Alan
Vray_Fur_Grass-Test.zip (550 KB)
Oh yeah, I just noticed that in the file I sent you, I was working with a mono-colored fur. If you want the fur to look like the material included in the scene (which works very nice for grass and carpets with a design), just apply the material to the Vray Fur icon.
-Alan
After a some tweaking I achieved the results I wanted with VrayFuf
Thanks Alan!
Nice!
Most welcome…
-Alan
