Grass material on vertical wall-curtain panel.
Hi! I’m trying to make a green wall. I try to apply the grass material to a curtain panel wall and it doesn’t work. I try also with a carpet material and still doesn’t work. Do you know how to solve this problem? Thank you
Does your curtain panel material have the word “Grass” in the material name?
However you may find that grass will not grow perpendicular to the panel. You’ll be better off nesting an Enscape asset into your curtain panel family, making sure to check the “Share” option of the desired / nested Enscape asset.
