its been 2 month that i started working daily with enscape and so far so good. But im being experiencing some issues with the grass in sketchup. When the grass is too far from the camera its stopped to render and appear only the texture (see the images attached). Is it a bug or just a software limitation?
Thanks and sorry for my english.
Right now, that’s a software limitation in Enscape for better performance. We will try to get rid of that, thanks for noticing!
As a suggestion for hiding the transition… Would it be possible to tie the brightness of the alpha channel to the distance and allow it to smoothly fade out instead of just becoming less dense with distance?
That’s a good idea but in this case not applicable, because the grass blades are not drawn via alpha blending. They are normal opaque geometry with cutouts.
