Grass strands Units
Hi, i want t try fur grass in Envision, but all measure units are in meters. In my opinion it should be in centimeters, because when i wanted to make grass half a centimeter thick, there was 0,00 m value. If it is a problem to use centimeters, you can set it for four or more digits, 0,005 m for example..
Hello @kenancakir ,
Thanks so much for your feedback — we really appreciate it!
We’d love for you to add it to our brand-new Ideas Portal, where you can not only share your suggestions but also track their progress as we work on them. [Click here to access the portal]
Regards,
Ana ​
Hi, please note that you can change your project’s global units setup from File > Project settings > Units (to m,cm,mm), regarding the issue with support for higher precision decimals, we have it logged and it will be handled in [EC-1476]. Thanks for the feedback!
Thank you, i add one of my idea to the ideas portal.. Not this topic of course, mr. Karampelas showed the solution..
