Grass too Dark in Enscape
Hello, I am having a problem with the dark appearance of grass in Enscape. I am using Sketchup. Both programs are latest versions available as of August 11, 2021.
The issue is that if the material is set to default, the shadow brightness looks normal and is quite acceptable, however it’s obviously not rendering as grass in Enscape. Once the material is set to ‘grass’ type in the material editor, the shadow brightness of the grass becomes dramatically darker to the point it looks very unrealistic.
Render export with grass texture set to ‘default’:
https://www.turnervisual.com.au/images/No_Grass_Setting_On_Grass_Texture.jpg
Render export with grass texture set to ‘grass’:
https://www.turnervisual.com.au/images/With_Grass_Setting_On_Grass_Texture.jpg
I have tried as many settings as I can to see what is going wrong here but have not been able to identify a solution.
Thank you.
That’s because when you have the texture type set to generic it is just rendering a flat surface with a texture map. Once you change the texture type to GRASS it actually adds geometry and therefore, gets darker do too shadows being generated. I never use the GRASS type for textures since it looks terrible. You can get away with a good hi-res texture and a normal map. If you really want to show blades, use skatter since they have default grasses that look great and it works with Enscape.
Thanks for the tips with Skatter - I’ll give that a go. Support’s response is that this is normal behaviour which I find quite terrifying. The grass looks absurdly dark and hyper-unrealistic.
Yep
