Gridlines in reder mode
Helllo.
Is it possible to add a gridline like there is in the video editor.
I think it’s a useful tool to adjust de camera view.
Like the image in attachment
Thank you
@GT3 , thanks a lot for your inquiry - Natively it isn’t currently possible to add a grid like you can through the video editor, but as a workaround, you may be importing a grid as a watermark through the “Enscape Window Settings” - Which can look like this for example:
This may probably not be a grid you’d want to use yourself, but I’ve acquired a random one from here just for showcase.
Alongside, please also forward your feature request to PM directly through our portal. Much appreciated!
Ahhhh, It’d never occurred to me to use the watermark feature for grid lines, that’s a good idea.
Just got to remember to turn if off prior to rendering.
@Demian_Gutberlet how about a SCRIPT like this.
GitHub - cb109/imagecomphelper: :pencil2: Image composition utility to frame camera shots in 3ds Max.
It’ just an idea.
@Demian_Gutberlet I use a slightly different workflow;
MY WORKFLOW;
SU - watermark: raster 1/3rd / Golden / Silver/… or other ratio.
E3D - watermark: company branding/logo
By doing this. You will have always the grid aid to make interesting compositions. Non visible on your renders.
And the benefit of having your company branding instantly on all your renders.
It would be a nice feature to have the rule of thirds directly enabled with a toggle function similar to the one under Video editor - Show Gridlines.
Have attached a link below from Alex Hogrefe explaining the needs and the benefits of having such a feature inbuilt. At the moment my workflow is to do a quick render and check the Rule of third in Photoshop and back and forth till getting it correct.
Composing Your Perspectives | Visualizing Architecture
Would be time saving and useful to have something (toggle feature) similar to the image attached below.
Welcome to our Forum!
I have moved your post into this existing thread, I hope that is okay. Allow me to refer you to my second reply here:
Whether or not this workaround is sufficient to you, make sure to also forward your Feedback through the portal as detailed above. Thanks a lot!
Here’s a sample file with the step by step to add a grid to Enscape’s camera view. https://www.linkedin.com/pulse/adding-camera-grid-photos-mode-enscape-phil-read/
Just added to the roadmap. Hoping we can get this implemented.
Have this idea died? Composition is crucial for imaging and renders…
Will WE have guide lines inside Enscape and not a workaround watermark? (thanks anyway @phil_read )
Cheers
Hi there, no idea is not dead at all :slight_smile: We’re working on it, to be honest it will take some time to deliver though. Most probably we will be delivering it in the second half of the year.
