How do you guys manage growing model and texture libraries. I assume most of us keep models and textures separate (i have one drive mapped for models, proxies) another one for textures.
Now when you buy some model collections they usually come with textures. Do you split it? Or keep things together?
my technique generally involves getting everything all mixed up in different folders, with as many duplicates as possible, and then forgetting what i do and dont have, eventually digging what i need out of a job archive i remember using it in, or performing a whole drive search to find it if i can remember the name.
as you can imagine ive perfected it over many years.
This is my method too. Maybe we read the same book on organization? I think it was written by Jackson Pollock.
I have one folder called assets, with several descriptive folder under it, like textures/brick and models/furniture. I have the assets folder mirrored on another machine and synchronized to Carbonite. I do not like wasting time looking for things so I am very tidy with my assets; everything has a place.
hmmm…interesting glorybound…but I with Super Gnu and MoonDoggie on this one.. ![]()
until you spend more time looking for assets then working ![]()
so Bobby when you buy some models you split it into your folders?
Same here, big mess, was thinking, if there is any soft, where I can tag files with keywords, with search possibilities, able to find duplicates, in results capable to display different image and 3d formats?
adobe bridge ?
You can do that with Google Picassa too. Not that I do, though. It’s kinda hard to start new habits.
After trying ACDSee and Picasa for a while, I’m back to using Bridge to catalog image files - it’s the only one that can view and keyword all the various formats I end up using. I don’t have anything for organizing Max files though - just trying to remember to name things appropriately for later recall. It would be a good system if I could finally learn that names like “bottle_01_012_final_final2” do not make sense even a week after a job is done ![]()
b
Priceless.
Sidenote:
I have a lot of “draft_01_revision_03_final” files…
hahahah good one ![]()
Humh tricky !
Assets
2D > Textues/photo/ref/etc etc My / Bought
3D > Arch/cars/scene/etc etc > Bought/ my
Finding files …
Windows Search FTW > Juty type Dirt in search window and tadaaaaaa everything is there ! ![]()
As to working projects its pretty much
2011/02/20 Mini WRC(always start by year/mouth/day - easies way to find back files !) > Scene/output/maps/misc > Scene files goes >
Mini 1
mini 2
mini 3
mini 125
Mini 213 v1
Mini 213 v2
mini 213 v15 Fix v1
mini 213 v15 Fix v2
mini 213 v15 Fix v3
mini 213 v15 Fix v52
mini 213 v15 Fix v52 Ground fix v1
mini 213 v15 Fix v52 Ground fix v2
mini 213 v15 Fix v52 Ground fix v3
mini 213 v15 Fix v52 Ground fix v1324414 sky revision v2133 dust fix v23 blabla fix v23 Finnal v532 Final correction v321 Final revised v213
And so on so on… about 40 GB of max files ![]()
The Temp output files so far record is 250 gb yay…
I have a drive with all the libraries in there divided by application MAX, Sketchup, Autocad, Revit, Rhino, etc
I have another folder for Entourage 2D, Library 3D (divide by company, example: Evermotion, AXYZ design,ect) inside of each company by category) the models that I made them are inside my company name as well
for textures the same thing, Standard MAX2009, MAX2010, etc) by company and Custum (inside there is a folder per project that need a modified texture or custum made textures).
my Asset Drive has a Software folder where I have all the plug-ins and software needed.
X drive for Projects(active)
Y drive for Libraries
Z drive for administration (documents, contracts, invoices, etc)
O outputs ( I clean it every 2 months)
Q archives (zipped folder after the project died)
project name is like that 11001,11002( first two numbers is the year)
inside each project folder i have:
3ds (temp folder where I export geometry to be used in max from Sketchup & Rhino)
CAD (Autocad ,Revit)
SU (Sketchup)
IMG (Final images, Indesign file)
RED(Redlines )
RH(rhino)
MAX
OUT(when I send something preliminary to the client)
the reason why I use short names(8 characters or less) is because It will be easier to recover them and proccess the info if the Hard drive fails.
Fernando
Good topic…I try to do similar to to flino, mostly very organized, but it’s not perfect!
