We’re currently resetting our Hair-pipeline to use Hairfarm and V-Rays new VrayHairFarmMod, and during testing i always got an odd kind of jittering inside the hair itself.
First I thought it was a too low sampler setting, but additional tests revealed, that the Hair has some kind of z-buffer problem. Like V-Ray couldn’t really sort out the exact position of the hair in the 3D-space.
You can see it quite good when simply placing hair on a plane an giving each hair a random color e.g. with VRayHairInfoTex. A sample scene and the rendering result is attached. Rendered with Hairfarm 2.1.0.139 and V-Ray 2.30.01
Just rendered your scene with vray nightly builds on 3ds 2013 and everything looked fine so i guess what the problem was is now sorted.
You should contact Vlado if you need this before vray 2.4 will be out.
Btw …in the example scene the “Use Hair Farm Renderer” option in the Hair Display WSM is switched off (otherwise, the Hair would’ve shown strange outlines and massively increased rendertimes)
But I observed that when either merging an Hairfarm-object into a scene or when making a copy of an existing Hairfarm-object, that option is always switched on again, no matter if it was switched off or not before.
