Yeah i was amazed as i found out that FumeFX worked with latest Corona, also that a simple convert from an old FumeFX Project from me to Corona worked flawless
and this is a really amazing proof of it
Nice discovery, I’ve been waiting for fume to work in it. It does seem that if you want shadows on smoke you need to disable illumination map in Fume. Otherwise fume won’t even recognize the lights for some reason.
Aw, thanks for advice, got to test it out on weekend.
No problem .. but yeah it’s kind of a bummer. I’m sure in time things will get more compatibility. Also it seems there are no shadows if you have the “cast ms to other fumefx” and “receive ms from other fumefx” checkboxes checked. Assuming you are using multiple scattering.
