We have a maxscript for submitting things to the renderfarm which does all sorts of things, one of which is creating a VrayMultSubTex with a buinch of Paremeters.
It works fine in 3ds Max 2015 with Vray 3.40.02 but in 3ds Max 2018 with Vray 3.60.01 I get an error.
this is the line that’s throwing the error.
refalpha = (VRayCompTex name:"reflectie alpha" sourceA:wcol sourceB:refocc operator:3)
refglas = (VRayMultiSubTex name:"reflectiemask glas" texmap_num:1 from_id:1 default_color:(color 0 0 0) color_1:(color 0 0 0) id_1:1 texmap_1:refalpha texmap_on_1:true)
this is the error it’s throwing:
-- Error occurred in anonymous codeblock; filename: ; position: 448; line: 8
-- Runtime error: Property is read-only: texmap_num
-- MAXScript callstack:
-- thread data: threadID:24220
-- [stack level: 0]
-- In anonymous codeblock; filename: ; position: 501; line: 8
-- Locals:
-- refalpha: undefined
-- Externals:
-- [stack level: 1]
-- called from top-level
was this parameter not read-only in previous versions ? what happened ?
I uncommented it and it appears to work, but why would this work previously ?
