Hdri
For some reason I can’t see my HDRI as a background. I am using a VRayLight as a Dome and I have an HDRI in the Use texture. It renders fine, but my background is black. Invisible is not ticked!
Dropping the same HDRI in the Environment slot renders the background fine.
Try using JPG as backround maybe there is alpha…
I really only have one HDRI that I use, and I have been using for years, and it has always worked.
Do you have camera clipping enabled?
That bit be in the butt before, I’ll check.
yep! it was the clipping plane
