Hi
I’m struggling to work out the workflow to output a multipass to a PSD.
When I render it I only seems to have the regular save out setting s and not an option to specify as a PSD despite the Save settings set to Multi-Pass PSD. I must be missing something.
What is the right way of doing this?
Thank you. I’ve now learned that I don’t need to render to Corona VDB. If I use the regular render I can save the PSD. I’m not sure where I was when they were teaching that lesson!
You’re welcome ![]()
