help please vray for sketchup _ PNG IMAGE
Im using Sketchup version 7.1, the rendering is great but I have only one problem, when I render the house the palm trees appears with black rectangles, the palm trees are PNG images so I dont know what’s wrong…
someone?
my e-mail is bergkette@hotmail.com
0 voters
Re: help please vray for sketchup _ PNG IMAGE
Check this post!
http://forum.asgvis.com/index.php?topic=4310.0
He made a small tutorial for a glass block but it works if i understand your problem correctly the same as you have with your trees.
if that post doesn’t help, try posting a render. This is a forum, if you discuss the issue you’re having publicly on here, then you will be able to get input from the entire community. If you just post your email address, you’ll be limited to whoever is brave enough to send you an email (it’s dangerous these days, viruses, spam, scams, etc). Post an image of the issue you’re talking about. Information about how to post images can be found here:
How do I post images?
Use the link below to download the pdf manual for new features of vray for SU by Fernando Rentas… and go to page 24 of the pdf manual and check out the alpha transparency topic..may be it will solve your problem…
http://software.asgvis.com/index.php?option=com\_docman&task=doc\_download&gid=661&Itemid=536
also do keep visiting the youtube channel of asgvis…it helps
thanks I solved the problem, your comments were very useful, thank you all XD
