I have my primary computer set up with online and dongle licence. (forgive me the licence system is increadibly complicated. I have a dongle and online activation I think.
I want to test network rendering and I installed Vray as a server on the rendernode PC. I then installed th online licence server but its asking me for a dongle! Why cant it find the licence?
Can Chaosgroup please simplify the licence system. You should just log in during the install process
How do I tell the rendernode that it belong to my account that has a rendernode avalible?
This has been pure hell so if anyone can lend a hand I would appreciate it.
Please not that there is a dedicated help topic for the installation of V-Ray and it’s licensing. There is a section for DR as well: https://docs.chaosgroup.com/display/…d+Installation
Actually the system is not very complicated. While installing, make sure you select the render slave option. As long as the correct license server is specified using the IP adress, you should be fine. Works like a charm here. You don’t need to worry about the online license thingy on the render slaves.
The correct IP adress is the one of the machine your dongle is plugged into.
At least that means my computers can see each-other but how do I fix this error?
I went to the render node and logged used a web browser to log into the dongle using 192.168.0.60:30304 and I can see the licence server so why is it telling me it cant obtains licence when I render?
On the server I went to “Change Licence Settings” and for the primary licence server I put 192.168.0.60 and port 30304
Yes I found the advertising language used to be misleading. I purchased my licence with the belief that it came with 1 workstation and 1 render node. I believed was the reason why V-Ray is expensive. I made my choice to invest in V-Ray based on a misunderstanding.
Yes, I should have known better and should have looked more attentively but that is the problem of being a beginner. When you start out, you know nothing, your looking to invest in a render engine and you just cant make the same quality of choice that a professional can.
I think that Chaos Group should be really clear about what they are selling. I know it makes sense to them but it needs to make scene to “dummies”. Its the same reason a claymore mine says “FRONT TOWARD ENEMY”…to prevent that 1 or 2 idiots for making a stupid decision.
I don’t understand why they have separated the “interface” from the “render” licence. Is there any functional benefit to having an interface licence only? If there is no benefit then they should take interface 1 and render 1 merge them together and call it workstation 1. They should call additional render slave licences, “render slave” licences.
You can by or rent vray licences from authorised re sellers.
The price is discounted depending on how many you buy.
