Render with irmap calculation: 2:39
Render with irmap (file) from single frame: 2:19
Render with irmap (file) from multiframe 1-100: 3:15
Render with irmap (file) from multiframe 1-1800: 5:47
When irmap is longer in frames, is bigger my render time, why?
well I´m using gi low, and my irmap is 8mb only… I discard the network problem because these values are tested in a single machine…
DaForce: I already do the test with incremental add to current map and the size of irmap are exactly the same, I didn´t render with it so far, I´ll try tomorrow, but appears not be the problem…
I found this issue some months ago, rendering from saved irradiance map was about 3x longer than computing map and rendering it again from a scratch.
It seemed that irradiance map was corrupted somehow. It was set to multiframe instead of incremental.
I rendered it again with lower quality of irradiance map again and it was fine.
