Horizon Height
I don’t know if this has been brought up before, but is there any chance a option could be added to the atmosphere tab to adjust either the height of the default Enscape sky’s horizon line? I run into this most frequently when working on properties with a waters edge. Currently, I either have to create a “infinite” plane that extends miles out into the ocean or I have to deal with a little patch grey/black appearing between the ocean and the beginning of the sky.
Thanks a lot, this has been requested before a couple of times, so I’ve gladly forwarded your upvote to the existing feature request. :slight_smile: Let me know in case there is anything else you would like to add to your request.
I have a related issue but it concerns sky box images. I notice a mis-alignment of the enscape horizon and my skybox images (this occurs with Insta360 and Richo camera images). Is there some way to align the two horizons or perhaps “tilt/rotate up/down” the skybox image in some way?
(Here’s a link to the image: https://kuula.co/post/76lhW/collection/7PKLY)
There is not at the moment, mostly because a skybox image is fixed in a sense that it’s not easy to simply move it up or down for example as this would then distort part of the background. Still, there may be a feature available for exactly that, including distortions though, or other technical quirks. I’ve forwarded your upvote to the existing feature request on our agenda.
@Demian_Gutberlet In the Skybox example would it be possible to lower/raise the horizon line of the Enscape scene vs manipulating the skybox image? That would eliminate my issue as well.
+1 for this, finding a lot of my images with long views end up with big grey bands around the horizon that need attention in post.
Would be great to be able to have control over a vertical offset of the enscape generated skybox
+1
I posted about this some time ago.
Thank you. @SkipFifth , @jtubb , forwarded as usual.
I tried alleviating this by fixing a plane at sea level in my model (z=0) and then moving the whole main model up to the “real” elevation; in my case appx. 6700ft. It didn’t change how Enscape was positioning the horizon but would’ve been great if it had worked. Dragging the horizon up or down or specifying units would be excellent.
