Hotel Project, South Tyrol
This is my first Render with Corona !!
I hope you like it !
It is a good start, but you should probably add a more light to the image. It is difficult to see the details. What did you used to light the scene?
Thanks..
I used Corona Light IES..
Well, why don’t you also try using the corona sky and Sun? Or even an HDRI, this helps you having a better lighting for the entire scene and then you can tweak the IES as well.
Here is another Render of the Scene, now a Daylight Scene made with Corona Sun and HDRI..
I think you should calibrate your display - your images are waaay to dark.
