can only ipr the first camera.
way to reproduce:
create two cameras try to ipr the cam2
rotate the camera(the ipr dont follow) but instead follows cam1
change the vray rops camera to cam2. the opposite is true
Regards Alexis
way to reproduce:
Regards Alexis
I can’t reproduce this.
weird, i can reproduce it every time. have the latest nightly. have you tried tumble the viewport with cam2?
> try to ipr
What does this mean? How are u selecting the camera? In rop settings?
Ok, so it’s about VFB and right click, because from “change the vray rops camera to cam2.” it was really difficult to figure that out…
sometimes its sounds simpler in my head. should have been more clear. Where you able to reproduce it?
With right click yes, it’s because SOHO gets defaulted to ROP camera; I’ll try to figure out how to fix this.
the above things works fine now, thanks!
I have to questions:
1. is there a possibility to make the houdini interface to not lock when rendering with vfb?
2. When rendering from framebuffer by cklicking on the teapot its very bad at picking up lighting, material and disp changes, I always have to go back top the vray_rop and press render to disk to make sure it evaluates the scene correctly. Can this be fixed?
@LeoYfver , we’ll look into those, thank you!
@LeoYfver , managed to isolate the problem with (1) - it seems to only happen when the renderer is connected to any other node - we’ll look into ways to fix this.
@Gosho.Genchev Ah, we always have something connected so thats why we thought it never worked. Hope you can find a solution and thanks for looking into it
@Gosho.Genchev Any news on this? tried the 6 of march built and it still freezes the houdini scene
Sadly, no, the devs were busy with issues that had no work-around - we realized the code that causes this is also responsible for handling multiple ROPs chained e.g. to a Merge so decided it would be best to look for another solution instead of fixing one thing and breaking another.
I’ll ping you once we find a way to deal with this.
Best regards!
ok, thanks for the update!
