Hi again
Was trying to create a simple select materials AOV exports, and bumped into an issue.
In 3ds max using Vray I was always able to export the components of a blend material but in Houdini is not behaving the same way, see attached images and test scene (3ds max and houdini scenes).
In houdini it’s always exporting the final blended of all sheders in the blend even when targeting the individual shaders that make up the blend, and in 3ds max the material selects of those same individual components of the blend gave me the individual shaders in their blended amount.
Best,
David.
Vray_MtlSelects.zip (86 KB)
Hey, @david.anastacio ,
this is not implemented for Houdini at the moment, I’ve logged the request and will ping you as soon as we have it.
Best regards!
Hi, @Gosho.Genchev ,
This is quite important for us, looking forward to get it implemented then. Thanks for looking into it.
Best.
David.
Will be there in the next nightly.
Wow, that’s amaizing, thanks @bdancer
Tomorrow I’ll give it a try then
Hi again @bdancer
Unfortunately there is no new nightly to download, last one available is still the one from 4th of May. Tomorrow then maybe?
Best,
David.
We’ll try to restore nightlies asap (there is a holiday here today, so tomorrow yes…)
Enjoy your Holiday, you guys deserve it
Hi again @bdancer ,
Just tested the fix in the new nightly, still no good
VFH Build number:7121 hash:0014ac0 from 08 May 2020
Houdini 18.0.397
Windows 10
Best,
David.
@bdancer ,I think the update you did is actually missing in this last nightlies, because the update @chakarov implemented on the Bake Tool are also not there.
In the image I attached you can see the Bake tool was supposed to have UDIM ranges, but still has the UV Min/max ranges.
Best,
David.
@david.anastacio , in Baker Tool UDIM mask parameter is visible when “Bake to Texture Tiles” is ON, and the UDIM mask will be respected in the range in UVmin-UVmax. UVmin-UVmax is the actual range where the tiles will be baked, and the UDIM mask is applied over it.
Hi again @chakarov and @bdancer ,
Just updated to today’s build, the material select fix is finally there, thank you
I’ll reply to the bake in the other thread.
best,
David.
