one question is regarding the trees that show up in the background. i always have an issue with the flickering of these trees. they are 3d trees (bionatics) and in this case that just have a single vray material on them. any suggestions as to how i can get rid of the flickering?
i checked the uncompressed AVI (created out of Premiere) and that still had the flickering. Could it be from the images rendered out of MAX? The files are TGA’s 32 bit - Compressed - Pre-Multiplied Alpha.
I have the AA set to - Fixed 3, using Mitchell Netravalli filter.
nope, no procedural map on the tree objects. can something like a noise map cause that to happen?
i haven’t tried ‘adaptive’ for the animation - any suggestions for settings.
could it just be the amount of detail in the geometry? since it is so far in the distance - vray has trouble rendering the detail accurately from frame to frame? just a guess.
i re-rendered the anim (using Adaptive AA set to -1,3) and it seems to have fixed the flickering with the trees. i also rendered it to a higher resolution which i think helped as well.
there are a couple other things though. now i see some banding along the edge of the roof where it meets the sky. also, i am not sure why the playback is so choppy now. i created an uncompressed AVI out of Premiere then used the Windows Media Encoder to create the WMV file.
as for the banding…does it appear in the raw uncompressed version? if so, you need to play with the AA settings a bit…if not, then its due to the codec/format you used for compression
as for the chopiness…its either a compression/playback issue, or something with your framerate
I found that AA using simple two-level 1/4 with unchecking “filter maps” also gives nice results…adding a slight blur and grain in Premiere also helps to get rid of flickering abd banding…
I also have the issue of a chopiness when a video is played for the first time then it playes smooth…
I also tried different compressions/formats out of premiere and the ones I had better luck with were MPEG 1 w/ high bitrate as well as Miicrosoft DV AVI with DV(NTSC) comression…it plays back quite smooth but the file size can be somewhat big…
i am not having any luck so far with changing the bit rate. when i lower the rate, it still plays choppy. i’ve played with settings and formats in both Cleaner XL and Windows Media Encoder and had no luck fixing it. i am going to render out some more frames this weekend and keep playing with it.
