How Can I get Vray glass to look like this?
How Can I get Vray glass to look like this? Is it possible?
To me it looks like a simple glass shader, black diffuse, white reflection/refraction and maybe a bit of tint for the fog. The rest comes mostly from the environment reflection/refraction.
Here is a quick test done in C4D, glass parameters are the same in Max:
What @sirio76 said!
The coloring and the “thick look” both come from the “fog” which absorbs light passing through.
Without it, the glass with a white refraction will be comparatively difficult to see (along with being unphysical: there’s nothing with 100% transparency in nature.) if not for the reflections on it.
What are you using for reflection/refraction?
It’s just a 3d model of a lightbox that I use for testing materials and physical samples.
