Particular model, but I’m sure there’s others
SUV_002
has a white of 234,234,234
Hi Morne,
Thank you for pointing it out!
I can see that other vehicles have the same/similar setup.
I added a task on Jira to fix these values.
Tsetso
Thanks for the quick response
Hi again Morne,
This is just a quick update from our side - all vehicles with white color in the diffuse are now fixed (they don’t exceed the value of 200).
For the models you’ve downloaded already you’ll see an “update” label over the preview image.
To update the model, click on it to open the detailed view and under the "Import " button where it says “New asset version is available”, just click on “Download now” - see the attached screenshot.
Best regards
When using ACES, fresh snow is around 243, white acrylic paint is 227. So values above 200 are not wrong.
Do you mean linear RGB or sRGB values here?
