How to achieve realism for car front and tail lights ? I was searching for that but i couldnt find any valuable information about that…I really need professional artists advices please help me what should i use for front and tail lights ? Can you guys give me a detailed information…
Your question doesn’t imply that it has anything to do with corona or c4d, so this could be a very broad topic.
Could you please help narrow it down by being a bit more specific?
An image of your current attempt or at least a description would be helpful.
For those types of lights, I don’t see why a Corona light material applied to geometry wouldn’t work.
i used corona light material in my work which is first attachment
If I understand this correctly, then you’re mostly missing illumination from the lights and maybe some volumetric effects?
I think a crn light material (+ some directionality)behind some glass(a bit rough in the refr. channel) and maybe a bit dispersion could do the trick.
For the volumetrics, put it inside a box with a volumetric material or apply the mat. in the global volume slot scene environment of the render settings.
If you’re looking for a specific light pattern on the ground, that is not guaranteed and I’d use a crn light with an IES file applied.
Exclude possible blocking elements in the exclude list of the light.
Another thing is that it’s very unlikely they rendered those images purely in the beauty pass and then sent those out. Post processing in PS/AE etc. is essential.
Can you explain more about dispersion please , i didnt understand because im kind of newbie
/.html (489 KB)
I think this should help you: https://coronarenderer.freshdesk.com/support/solutions/articles/12000039646-how-to-enable-dispersion-
You’ll find a little bit of dispersion in most glass-like materials. the dispersion value (abbe) determines the amount. the smaller the value, the more dispersion you get.
Here you can find the values: Refractive index of CRYSTALS - diamond
Thank you so much for your help ![]()
