How to avoid texture tiling on large textured surface
Hey,
I’m looking for any tip or piece of advice to get rid of texture tiling effect on large surface such as brick wall building façade. I tried different texture maps but no matter the quality the issue remain.
Thanks ! :thumbup:
you need to use bigger textures, ie more bricks in the image.
Have a look at this one as an example https://www.sketchuptextureclub.com/textures/architecture/bricks/facing-bricks/rustic/rustic-bricks-texture-seamless-17256
It’s 12 euros a year for this site and I certainly get my money’s worth on a weekly basis
Thanks for the tip. Actually the texture comes from there, I’m a member :wink:
But I tried the one you suggested and the result looks much better.
Thanks !
No in sKetchup there is no other way than bigger texture, which makes file much larger. If I have more plain pattern like concrete or painted wall I can add bum texture And scale it arbitrary in ENS to by factors which ensure some shift in texture (1.17, 1.21, 1.07). it makes the seems of image less visible. but with brick texture You would rather not want bump to be shifted.. Or maybe from that far doesn’t really mater..
Use the displacement function of photoshop to make seamless textures
Great texture site, thank you
Try this;
Create SEAMLESS TEXTURES from Images with Materialize - FREE TOOL! - YouTube
@kris_dewinter
But He had seamless texture.. Even if texture is seamless it will look tiled when You zoom out far enough.. The more diverse in color, Value etc the earlier You will notice the tile..
