Hello, I need to render in max 2014 a scene from 2016 but I do have a message error.
How can I convert a max physical cam into a old style vrayphysicalcamera?
thanks
In 2016 you’ll either have to create a standard cam or a vraycam and match the FOV of the physical cam. Then you can downsave to 2014.
Keep in mind the exposure will be slightly darker as the ISO formula between VRayCAM and Physical use a different standard.
thanks, sure but sometime you have to deal with case that you don’t handle from the beginning. That’s why I’m looking for a solution, in case there is one.
