can someone help me how I can create this same surface or material in SketchUp?
it will be best if you create this material and pack it in a Sketchup file and post it in reply
In a 2D editing program - adobe ps or similar, you create a black-white reflection map - dark is gloss white is matte - this mean your brass accents will have darker color (preferable to make also a diffuse map with the accents in their brass color and outside tiling in white or whichever is your technical specification). place this reflection map into your reflection slot of Enscape material editor - afterward you tweak it from the sliders and color slots.
That’s clearly a serious of individual panels, raised from the substrate material at different heights. I’d make a flat substrate panel and give it a brass material, then quickly model those squares and rectangles in SketchUp and lay them on top. Would take no time at all!
Thanks for reply. I am not much expert so can you please create this for me and attach sketchup file ( additionally if you can record screen video while creating this and attach that video also i will be highly thankful ?)
Wow! you’ve invested all this money in a SketchUp and Enscape licence and are still learning the absolute basics to use them … that’s a brave investment … good luck /s
@abrar_youtube You might want to check out Fiver.com and pay someone to do that work for you. There are some skilled people on there that would be able to do everything you are asking for.
