How to fix shading interior rendering
Hey guys, does anybody knows how to fix shading in interior rendering? Why dark places like under the coach or the interior of a fireplace gets lack of real shading? I’m sending 2 images for you guys to check it out, one with roof placed and one without it. Why shading gets correct in these places once I remove the roof of the living, so it became and exterior place, and it lose shading, becoming more like a flat drawing, when roof is on? I’d appreciate any help.
Looks like you’re relying on the exterior sun to light your scene. Add some lights to your scene.
I’ve tried. But hasn’t figure it out how to put that natural real shading back inside the fireplace, under the sofa, and etc, in a daytime interior render.. Thank’s anyway for your attention!
Can you send a few images of the model not in Enscape?
Sure, but I’ve just erased all the artificial lights, since i couldn’t get what I was trying to.
Not sure what exactly you’d like to see..
the model looks great - you need to now add in some Enscape lights.
Red lights are primary
Blue accents, Set them off-screen (light value should be lower than red lights)
Have you made adjustments to your visual settings?
So, I’ve put some lights, but inside the fireplace there’s still clarity, like it was not a whole inside a wall, which should have a bit more dark shading, as when I render without roofing it. Also under the furniture, specially the couch..
My english is not that good, so I don’t know if I am making myself understandable..
I tried to make some adjustements on the visual settings, but still couldn’t be able to get the right shading in there, as it works adusting the whole scene together and not only specific places.. Probably I’m not knowing how to do it right. I used to work with Artlantis, and those kind of shading were automatically adjusted by the program (both interior and exterior scenes), as Enscape does when the scene is render without the roof (but turning it into an exterior scene). But as soon as I put the roof back in the scene, Enscape automatically adjust the scene getting rid of those “inside/under” shadings..
I know that in real life those shadings are different in interior/exterior places. But in my 3D model, seems like enscape softens it too much looking like there’s not shading at all, like a pure flat sketchup scene.
@DJaeger - Are you able to share your model?
Sure, no problem! Thank’s for your help.
Let me clear unecessary things up in the model.. Could I send to you through “wetranfer”? If so, could you send me your email address?
And one more question: Is there any possibility to edit Enscape cutouts?
I know it can be scaled. But, for instance, I tried to erase some parts of a table enscape cutout. On sketchup, I could seclted ir and erased it. But Enscape didn’t recognized and still showed it completely. (image attached)
I’ll DM my email to you.
you can’t edit Enscape objects as they are just proxies.
@DJaeger
Okay take a look - Is this the direction of what you’re looking for?
Nice! That’s it.
The only thing is I wanted to have this real effect but in a scene using only natural sun/day light. Or that you look and feels that there is only natural lighting, even if we use some artificial lighting. Don’t know how the other shadows would look though.
For example, have a scene in an afternoon/morning time, with the sun going inside the living through the glass doors, and etc.
To get that real mornings feelings.
We don’t turn on the lights in our houses in the morning in real life, right? That was I was looking for o make it 100% perfect.
Really interesting problem. That bad and good shading above do look completely different. Have you tried fooling around with the the AutoExposure checkmark - on or off?
Yes, I did. Tried it in many ways.. But since exposure changes the entire scene, I couldn’t “create” or force a smooth darker shadowing in there as enscape does automatically when it is a exterior scene..
I kind of wish I could look at the model too. Kind of fascinating. Maybe I will try recreating a little example of it for myself to see what happens. But I wonder if the actual finish you use on that fireplace interior has something to do with it.
Just on the simplest level, I seem to get the shading in the fireplace in both options, ceiling or no ceiling.
I wonder why your exterior landscaping is so dark in your option with the ceiling removed? Thx.
It is interesting though the shading in the fireplace is a little lighter with the ceiling…
I left a comment above. Thanks.
@jtubb @corosketch
Guys, I might have found what the problem is. And it has something to do with the image I’m using in skybox. Check these new images out.
I’m using the same position and time of the sun in both.
@jtubb - Maybe you were having a bad time trying to understand me, since you had my 3D model, but not my background image. So you probably were not having that same "flat"shading on your computer as I’m having here.
I’m wondering why Enscape is having some difficulty to set a real shading with that image though.
Anyway, I think the key here to really solve it is to change background, which I don’t think it’s fair, but it’s ok..
I really appreciate you both trying to help.
I’m also sending the backgroung image if you guys want to set it in there to check it out. (but it seems the website here is changing size and reducing it..)
@corosketch - I think I might have found the tricky issue.. Not sure if you still want to take a look at the model, since clearly it’s a background kind of issue, I assume.. Just let me know though.
Thank’s anyway.
@DJaeger
Take a look at this video. He shows exactly what you want: an interior scene with natural lighting.
