we just got a MAX-scene from anoffice, with the VRay-RT .dlr inside. We don´t have the RT-Plugin. If we want to render the scene in the network, the scene doesn´t render because of the missing .dlr.
Does anybody know how to get rid of this .dlr?
Help is pretty much appreciated, cause we need to start rendering in 2 days!!!
this works. The problem is, that if you don´t have the RT-Plugin, you can´t switch it off. It shows Scanline as active Shade renderer anyway. So the guy who created the scene has to switch RT off and save it. Than it´s possible to open and render it with a system where no RT is installed…
I thought there was a blur script for removing missing plugins, but its only for missing modifiers.
I am pretty sure there is a script floating around somewhere for this
For some reason I figured out that on a different computer it says “missing renderer” at the active shade box. if it´s like this, you can just switch to scanline and it´s working. I couldn´t figure out when which state is appearing…
