So Vlado posted the above in another thread. I can’t find mention of this technique in the helpfile anywhere. Does anyone know how this works? Or if it’s in the help, I’ll take a link to the page. Thanks.
- Neil
- Neil
Is he referring to clever uses of this maxscript topic:
Node User**-Defined** Properties and Methods
I’m not sure. I’m assuming no, but it’s the only thing I can think of.
Also Soulburn, sent you a PM with a quick question.
You will need a 3.0 beta for this. In the file name in VRayHDRI, you can put tags like “c:\temp\diffuse_<mytag>.jpg”; then in the User Defined properties of your node add the string mytag=someStringWhen V-Ray evaluates VRayHDRI on that object, it will look up the mytag user property for that node and use the texture “c:\temp\diffuse_someString.jpg” for that node.
Awesome. Thanks Vlado, I look forward to using that in the beta.
- Neil
