I just installed the programs again and something is different. The resolution of Interactive Render is lower, and when i zoom it doenst get better like in previews versions of the program that i was used to
Hi there, I think what you’re looking for is the Upscaling factor.
If you open your Render setup window and go to the System tab, you’ll find a parameter called “Image upscaling factor”. I think yours might be set to 2. Change it to 1 - this will essentially double the resolution of your interactive render.
Hope that’s what you’re looking for!
Yep, it’s upscaling factor.
Render Setup > System > System settings > Change upscaling factor to 1.
Also, it’s a great idea to upgrade to Corona 8 HF2 - Download | My Chaos
Thank you! ![]()
