How to place a shadow to a HDRI-Background in CUDA-Mode?
I need urgent help with the following problem:
Precondition:
I work exclusively with the CUDA engine in CUDA + CPU mode!
V-Ray Version 6
Task:
I want to insert an object in a background image (HDRI) and get the shadow in the background.
In V-Ray 5 I had no Problems with this task.
Unfortunately, this does not work for me as shown in the following video:
and
https://www.youtube.com/watch?v=IuBxbY4R\_bo at time 4:50
I have tried all possible combinations in the wrapper-Material.
Unfortunately without success.
If I calculate only I im in the CPU engine I get the shadow displayed in the VFB.
Thank you very much for a very quick help.
Regards Ronald
Hello, Ronald,
Thank you for reaching out!
We have identified the issue preventing the matte effect of Wrapper materials to appear when using V-Ray GPU.
An upcoming hotfix will contain a permanent solution for it.
In the meantime, there are a couple of workarounds you can use to overcome the issue:
  • Workaround A:
        - Open the SketchUp Ruby Console (Window > Ruby Console or Extensions > Developer > Ruby Console depending on the version of SketchUp installed).
        - Paste the following script in the console. Make sure you substitute Wrapper_v6 with the actual name of your Wrapper material and keep the “/” in front of the name. Then, press ‘Enter’.
    scene = VRay::Context.active.scene
    scene.change {
    scene["/Wrapper_v6"][:alpha_contribution_tex] = -1
  • Workaround B:
        Use a Matte Wrapper material created in V-Ray 5. This can be done by opening the V-Ray Asset Editor and load a V-Ray 5 Wrapper vrmat file (the ‘Import Asset File’ located at the footer of the Asset Editor).
        If you have the V-Ray 5 Material Library still existing on your system, simply navigate and load the following file.
    %UserProfile%\Documents\V-Ray Material Library\AEC\materials\v5.0\Materials\Diagrammatic\ Matte Shadow Receiver.vrmat
        Alternatively, download and load it from here:​​ Matte Shadow Receiver.zip
Hope this helps!
Kind regards,
Peter
Matte Shadow Receiver.zip (23.9 KB)
Hi Ronald,
I just want to notify you that V-Ray 6 for Rhino, hotfix 1 was recently released and it addresses the Wrapper issue.
Note that materials created with the official V-Ray 6 or the beta will have to be re-created to work correctly.
Konstantin
