How to render using HDRI maps?
Hi i’m a newbie and would like to know how to render with HDRI maps. Could someone provide me with a template(some settings like where to place the hdri file, where to input the intensity) so that i can modify from there? Thank you.
Re: How to render using HDRI maps?
If you want to use the HDRI to illuminate your scene, place the HDRI under “Environment” tab on GI Color. If you want to use the HRDI for the Background, you should put the HDRI on the BG Color.
Also you can override the reflection and or the refraction with an HDRI. To do this just enable the "Reflection and or the “Refraction” option on the “Environment” tab.
How to use the HDRI
1. Click on the “M” near GI Color
2. Select “TexBitmap” as your texture mapping type
3. Change your UVW Type to “UVWGenEnvironment”
4. Load the HDRI file
5. Select the type of the HDRI. In V-Ray you can use 4 different types (Spherical, Mirror ball, Angular and Cubic)
6. Increase the GI Color multiplier to your desired intensity. If you are using the Physical Camera this value should be very high. I guess 75 or even more.
Please see the attached images
Render test using only HDRI
Best
i have written also a tutorial here…
Hi NOMERADONA
Nice tutorial!
Nice tutorials, Fernando and Nomer. Thanks for sharing.
Hi Fpedrogo and Nomeradona
good tutorials i belive it will be very useful for people like me! (rookies ;D)
thanks a lot for sharing with us :wink:
Cptos.
Castro
sorry to start this thread again,
how do i control the size of the HDRi image in my background slot?
ive tried changing the values for placement etc but no change in the render?
any advice would be great,
thanks
dean
Cannot adjust the size of and HDRI Bg image…unfortunately.
Best way to create the background is to post process in Photoshop.
As far as why we cannot adjust the HDRI yet, i dont know. Photoshop offers more freedom and fine tuning anyway. Hope this helps :-X
-Gallystops-
Thanks for the response gallystops,
Yes I always ps my backgrounds, but I use the hdri for the reflections in the glass etc, and sometimes the hdri in the reflections looks too big for the scene so I hoped I could adjust it!
Thanks anyway
Dean
Hi guys,
I am using HDRI for the first time for both background and image based lighting.
I have issue with the perspective. My model seems to be floating and not matching the perspective of the hdri image.
How do i fix it?
Thank you.
_KN
master nomer nice tutorial, kip it up.. :smile:
