Hello, most of my old asset are build with ColorCorrect for 3ds Max 2019 is released – Cuneyt Ozdas.
I would like to get rid of it and repalce it with either Vray color correction map or the one provided by max.
I tried the script available on scriptspot but it doesn’t works (too old and no updated since 2011).
Thanks to share your solution as I’m probably not the only one in this case.
Hello, seems I’m the only one to face this issues or the only lazzy guy that prefer to look for one click solution instead of thousand one to replace all colorcorrect map by another map!
youre not but as far as i remember there is no vray color correction map as of yet.
furhtermore, i remember trying to get rid of Color Correction plugin from Cuneyt Ozdas with th emax one…no chance…always had to start using maxes one and replace this over the years ![]()
There are two CC maps with shipping with v-ray, inside the pluginNodeTex map.
Unfortunately, there is no guarantee that either (or Max’s own) will be able to replace what has been done with the other CC map (code is opaque, and even if it wasn’t most likely it’s quite different between each.).
Darn, I have a similar issue :-). Most of my ‘older’ materials have the CC from Ozdas. Trying to get rid of it as well. But can’t seem to find a one click solution…
*) I have tried the plugin, it installs fine in advanced mode for max 2021 (albeit with some minor complaint).
It seems to be working just fine.
*) The author is now an Autodesk employee, so perhaps he could provide for a conversion script towards the Max’s own?
*) I’ll look into this on my side for the fun of it, but i am utterly unsure i could in case distribute a tool to convert it.
Converting between color correction tools would be very hard, since each tool is missing a lot of features the others have. Heck, even features that should be the same, like brightness, some plugins define brightness as a multiply, some define it as an add/subtract, some define it as a mult with a curve associated with it. So unfortunately, I think writing a good conversion script is an impossible (or improbable) task.
- Neil
hear hear!
I hate myself of using such plugin. going over all the asset is very consuming task.
That’s what I thought as well, but couldn’t hurt to try. Thanks for the input Neil. Guess I’ll have some work to do ![]()
I still hope one day for either adesk or vray to make a great Color Correct with a slick interface, one worth moving over to ![]()
- Neil
2021 has new OSL ColorCorrent map. It is easy to modify and custom Qt UI can be used.
If you think something is missing, I’m sure Zap can easily improve.
Does ALL the OSL maps work with VRay?
That color correct is too limited for my usage.
Zap has my full color correct design spec, so maybe one day he’ll implement it, but since max 2022 will be my last new copy of max (since they are eliminating the maintenance license), I think its unlikely to see it implemented before I go. But hopefully he’ll do it one day and it’ll help out you guys!
- Neil
Yes. everything works.
One good thing about OSL is.. you can use in any max version. You can even use 2021 OSL in 2019.
All max OSL shader is apache license. You can just copy from any future version of OSL folder to 2021 OSL folder. ![]()
BTW, may I see that spec, too?
Cool, wasn’t aware of that. Thanks for letting me know.
Sure thing, I put a copy recently in this thread…
- Neil
So.. just as a discussion, does it have be all in one maps?
OSL Component, Curve, Remap, etc can do all those in more granular manner.
That’s the idea. I find having all of these in a single map presents the user with all the possibilities without the need to be constantly creating new nodes. Not to mention it makes materials graphs more easily readable, I detest 300 node material trees.
- Neil
So I’m trying to upgrade to Max 2022, and see that this hasn’t been resolved yet. I contacted the author but haven’t heard back from him. I’m willing to pay for a solution. I’d rather have a converter to some Max equivalent as I don’t want to rely on third parties anymore. I’m very much willing to pay for this as I have a LOT of assets and materials that rely heavily on this. Anyone have an idea?
Edit: it seems that the script is working though (more or less, I’m loosing some detail/contrast though, when using contrast and gamma at the same time) but I need to find a solution to apply it on 100+ different material (.mat) files and also on some .max files. Is there a way to automate this?
