How to see which portions of scene need most ram
I’m trying to learn which portions of my scene are using most ram when rendering so that I can start to fine tune and optimize my scenes. What kind of technique should I be using to do this?
(I have a scene at the moment where Windows is telling me it is using 9.7GB when rendering! The scene is very simple - a rug (with vray fur), a high poly bed, 4 or 5 lights, curtains with a vray2sided mtl on them. Nothing special really. 9.4Gb seems a lot, especially when I set the max limit to 7.5GB in vray!)
There may not be much of a connection between memory usage on the CPU and on the GPU, so it might make more sense to look at the GPU usage directly, f.e. using a tool like EVGA precision. If you render the scene with a white material override you can see how much memory it needs just for the geometry/lights. With that said, you can fit a fair amount of geometry on the GPU; it is usually the textures that are a problem.
Thanks Vlado - I will investigate that.
Unrelated to RT, if I wanted to see how much RAM my scene is using to render, how might I go about this? I’m just surprised that my relatively simple scene is taking so much to render. I am using XREF materials from a separate scene (which has A LOT of materials assigned to little boxes, though only a very few are used in this particular main scene) - could this be an issue?
Probably is not the most precise method but you can track the memory use for “3dsmax.exe” process in windows task manager.
