hello
since vray next have no active shade rendering, i no longer be able to use vray rt in viewport only in vfb. is there a way to fix this? or is it deprecated permanently?
For now there is no option for ActiveShade in the viewport with V-Ray. Do you use it often ?
Yavor
There will be some developments in that regard in one of the updates.
hello, yes i used to to use the active shade as i have a small monitor, i will stick for the ipr window for now.
thanks
