How to use the corona8 decal function
How to use the corona8 decal function,Is there a tutorial,Patterns are not displayed correctly after use
Hi, have you dropped the texture onto the decal object with UVW mapping? Could you share a screen grab of your setup please? John :slight_smile:
otherwise, here’s a simple example
https://forum.corona-renderer.com/ Using the new ''Decals'' feature #msg193113
also, worth checking out Max’s thread
https://forum.corona-renderer.com/ CoronaDecals playground! #msg190883
Perhaps this might help?
https://support.corona-renderer.com/hc/en-us/articles/4417034655505-How-to-use-Corona-Decal-object-in-Cinema-4D-
is used UVW
There should be no errors in the operation steps, but I don’t know why the image cannot be displayed normally, is there a requirement for the image format, or is this a bug?
I still don’t understand, thanks for the reply
Can you try using a Corona bitmap and let us know the outcome?
still doesn’t display correctly
Hi there, can you share the scene with us? If so, please feel free to zip the file and forward it to us at support@corona-renderer.com. Thanks!
Okay, thank you
In max I was trying to drop texture on the material slot in the decal roll out and it would not let me.
That’s the way it works in Vray…how come?
