Hi, I’m trying to figure out how to use the randomise UVW map ? with the floor generator script ? I have one big timber texture that I crop a certain part off floor boards, I just need to offset the V.
Does it work on sub elements ? do I still need to apply a material element id the floor boards ? and use the multi map as well ?
Unfortunately we do not have the “by element” option in multimap or uvw randomizer yet. So the solution for now is to apply the “material by element” modifier, and then set the randomizer to mat id mode.
I can’t wait for the “by element” option as well. This will change a lot of things.
Thanks Maru,
Yes I look forward to by Element option too.
