i have both V-Ray irradiance map and Vray image to OpenEXP converter
but i dont know how to use this application
sould i put it in indirect SketchUp folder or SketchUP viewer
onother problem
i use 3Dmax9 32bit , i can’t install 3dmax6-8,9 (64-86 bit) Vismat converter (i need to convert the material from 3dmax to sketch up)
so i wonder is there any 3dmax9(32bit) vismat convert ?
and where can i take it
someone help me ,i need ur guide
thank so much
Re: how to use Vray irradiance map and iage to openEXP
Here’s the material converter for max9 32 bits:
and here’s a tutorial of how to use it:
The irradiance map viewer is simply to view/work with saved irradiance map files. Unless you are using saved irradiance maps for different views or animations you probably don’t need that tool.
The VRImagetoOpenEXR converter is only needed if you are rendering to a vrimage. VRimage files are typically only used for large resolution, where saving memory is important. There are a few details with using it in the Large Resolution tutorial
The material converter sounds like the one you need. Follow the link that Ibontxu posted and that will get you there. Also there is a read me file with the installation. That has the details on how to use the converter.
yeah i got it and understood
Ibontxu : thank for your link ,you are the nice guy
Dalomar : thank for ur guide ,i have more knowledge from your information thank so much
