Hello i just begining to use vray and i notice that is so noise in my render, wich is the cause? thank’s
Re: I feel some noise in, can you help me?
i believe you used IC & LC for your GI. & the noise is normal. Under the image sampler, lower the noise threhold setting. but not lower than 0.002 or u will get a long rendering time. Hope it helps.
i gonna to try this option
i achive better results, but still a bit noise.
Anyway is better after your trick ![]()
Other thing, in display cases i put a material glass, architecthural_glass but i think that the images below is deformed, do you have any council to improve it a more realistic glass? or do you think it’s ok?
thank’s
i forgot the new image with the extrange glass i think i was wrong in some step. thank’s
can u post the setting of yuor glass? bu just looking @ it, i think you need more transparency in your glass to make it look more realistic. for the noise, one more thing u can do…is to increase the “subdivs” under Light Cache (if you use LC as your GI)…hope it helps.
