I am creating a scene using the “reference image” attached, but when I actually create it,
the ceiling color, like in the “corona renderer,” reflects too much of the floor color,
which becomes visually unpleasant. How can I achieve a more accurate reproduction?
You need to make the floor a ray-switch material. Have a look in the corona docs for more info: Corona for Cinema 4D
Thank you! I’m glad it worked out for you!
As for your question, is it difficult to reproduce it using just one material in the current situation?
Not at all, you just need very carefully and precisely measure every characteristic of every material in the reference object, make sure that all the lights have precisely calculated intensities, colour temperatures, spread angles and so on. Don’t forget to take into account characteristics of camera sensor and apply exactly the same tone mapping and post processing like in the reference photo. After that, i think Corona will have no trouble at all to provide you very accurate rendering on its part. Alternatively, you can save yourself from a lot of headache and do a little cheating, like it was suggested by davetwo.
Is it because the floor is made of rayswitch material in reality? ![]()
Just an observation…
I’m starting to find this being an issue connected to some sort of ‘bias’ - maybe part of one that can be observed in surfaces/shading when camera (eye ray) is hit at very low angles (then it tends to darken surfaces) while with GI parallel surfaces it tend to ‘over-bleed’ opposite ones… hmmm…
PS.
Yes, both can be ‘corrected’ via ‘RaySwitch’, but from user perspective better fine tuning (less bias) would be preferred.
