id love a corona to vray script update as well.
got some projects that ended up half way on both corona and vray on now need to go to vray.
be great to be able to just jump between the right tool
thanks in advance
thanks in advance
I think thet will be one very helpful Corona 1.0 to Vray 3.1 and 2.4 ![]()
Really need a converter. When its done?
Yes, I would also be very interested in a corona to vray converter with the latest versions.
Im sorry, but Im sort of very urgent to convert corona material into vray material
when do you think its possible
You have my thank you..
Thank You very much in advance
New Corona to VRay converter is done, but needs some testing.
CoronaToVray_Converter_04.ms (34.9 KB)
Thanks very much! ![]()
Please save any primitive with this material (Marble Polished…) and give me a link to it. I’ll try to investigate what happened.
He’s probably using an older 2.x vray version where the selfillumination property did not yet exist
[/quote]
ok.let me do it
Seems it doesn’t work with Corona 1.2.1
What about the new version of the script?
Cheers.
Hello!
What can cause this type of error?
Anyone got this script workin’ (corona to vray) ?
yeah id like to test the sccript too, if it works with latest daily?
worked fine for me in 1.4 just did not convert corona layered materials
Script Worked very well for me .
Vray 2.40.04 licenced user.
In my experience, CoronaAO doesn’t translate properly with this conversion script if the AO is in the diffuse slot. I’m not sure if it matters in other parameters, but I can confirm it doesn’t work in the diffuse.
Please update CoronaToVray converter to support Corona 1.7 and Vray 3.6 - Triplanar texture and so on
Thanks in advance
